  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
sandbaggeruk
Members
  • Joined
  • Last visited
  1. Hi all, Although the kit supplied propellers are of good qualify, I chose to use a replacement. Proper Planeโ€™ wood laminated (WP005) propeller. Tamiya clear orange was lightly airbrushed over the propeller to give a varnished effect. The blades were airbrushed with Tamiya Royal Light Grey (XF80). Final clear coat of semi-matte was airbrushed to seal and protect the paint and decals. Tamiya Weathering Master Set A (Mud) was lightly sponged across the blades to give a worn effect, Mike
  2. Hi all, The Bentley BR.1 engine is finished. The only modification was the addition of the twin ignition leads, not that you can see them when the engine is fitted. Next up is the preparation for the pre-rigging stage, Mike
  3. Hi all, I thought I had posted updates before now. Obviously not ๐Ÿค” So, the cockpit has been completed and fitted into the fuselage/lower wing. The only modifications so far was the addition of fuselage internal bracing wires. Also flight control cables and replacement pilots wicker seat. Mike
  4. Hi all, The Albatros D.III (OEFFAG) is completed. I'll post shots later on the forum. Many thanks for your support and comments throughout this build. Mike
  5. Hi all, Here's the Lukgraph 1:32nd scale resin cast/3D printed Albatros D.III (OEFFAG). Serial 253.12 as flown by Oberleutenant in der Reserve Ludwig Hautzmayer, Commanding Officer of Flik 61/J, operating from Ghirano, Italy, during the Summer of 1918. As usual, a fully detailed build log in PDF format is available to view or download from my web site: https://mikesww1aircraftmodels.com/ Mike
  6. Hi all, As the build of the Albatros D.III (OEFFAG) is finished, I thought I'd start on the next . Sopwith 2F.1 Ships Camel, serial N-6764, operating from HMS Lion from April to June 1918. Mike
  7. Hi all, The pilot figure for the model. This is the Aviattic figure (ATTRES031). I found the head to be a little small and not in proportion to the body. Therefore, I replaced the head with another, I thought more in scale. For those interested, I should be posting completed model shots on Monday evening, Mike
  8. Hi all, Well considering how notorious decals in Lukgraph kit are, these applied OK. That said, a few folded over on themselves during application, which required some deft tweezer work to unfold them. I've found the best way to apply them is to soak the decal and surface and basically float the decal off onto the model. Even so, the slightest surface imperfection will cause them to catch and fold. The kit decal sheet has a set of very small serial numbers, but no indication where they should be applied. However, I assumed these are flight surface serial numbers and would have been applied to leading/trailing edges. Upper wing, ailerons, lower wings, tailplanes, rudder and elevator. Possibly for interplane and cabane struts as well, although this model struts are black, so they wouldn't have been visible. The dreaded carpet monster swallowed up the photo-etch windscreen frame. Fortunately, I had a kit spare that is about the correct size and shape. So now it's onto the figure and display base, Mike
  9. Hi all, Nearly there. I just have the fuselage decals to apply. Rigging finished. The engine coolant pipes have bee fitted but need modifying. One was too short and the other too long. Propeller fitted and the Anemometer (on the right interplane strut. I've also added what I assume is a fuel pipe from the auxiliary tank in the upper wing (left of the radiator). This pipe is routed from the underside of the upper wing and across the cabane struts into the fuselage. I'll post reveal shots once the figure and display are done, Mike
  10. Hi all, Well all pre-rigging fitted. 008 and 0.12 mm diameter mono-filament, 0.5 mm Brass tube and Proper Plane turnbuckles (RD-005 and 018). Landing gear and upper wing fitted. Now it's onto final rigging, Mike
  11. Hi all, Just a few of updates. The photo-etch access panels on the lower wing fitted. Also the radiator brackets at the rear of the radiator on the top and underside of the upper wing.access The rudder, tailplanes, elevator and ailerons fitted. Also painted the red stripe across the fin and rudder and upper wing radiator. Next step is to weather the flight surfaces, Mike
  12. Hi all, The basic flight surfaces are done. Airbrush base coated with MRP Khaki Green 3/G3 (MRP-333) Masked off internal structures with 1.0, 2.0 and 3.0 mm strips of masking tape. Airbrushed first coat of MRP Clear Doped Linen (MRP-256) Masking removed. Airbrushed final coat of MRP Clear Doped Linen (MRP-256) to fade back the internal structures. Aviattic Off White on Linen (ATT32241) decal applied to all surfaces. Airbrushed a sealing coat of Tamiya Semi-Gloss (X35). Kit decals not used for crosses as they are translucent and a bit fragile. Instead I cut and used masks to airbrush the crosses with MRP Night Camouflage WW1 (MRP-255). Now it's onto photo-etch parts on the wings before assembly and weathering starts, Mike
  13. Hi all, The kit supplies two different propellers, one for a 153 series aircraft and the other for a 253 series aircraft. The 153 series propeller looks to be a Knoller-Jaray Wein type, but the other propeller is not. The Windsock Data File No:19 - Albatros D.III (Oef) (P.M. Grosz) has photographs of 253 series aircraft with propellers that appear to be neither of those in the kit. The Wotan Type 1 (3202) propeller from LF Models seems a fairly good match to the shape of those photographs, although Wotan propellers were probably not actually used. As usual with WW1 aircraft, uncertainty exists and this time which propeller type is needed for my particular aircraft model. So, I've decided to change the propeller and use the LF Models propeller (I have one in my stash), but with Knoller-Jaray Wein logos, Mike
  14. Hi all, The kit supplies two 3D printed propellers, one being for the 253 series aircraft. However, the manufacturer of the propeller is not stated. The kit does not supply decals for the two supplied propellers. The only photographs Iโ€™ve found that show what appear to be the propeller logos from manufacturers โ€˜Jaray Weinโ€™ and โ€˜Lohner Werkeโ€™. These decals are in the โ€˜LF Modelsโ€™ Austro-Hungarian labels (C3205) set. As I was unsure of manufacturer of he 25s series propellers, I opted to use โ€™Lohner Werkeโ€™ logo. Mike
  15. Hi all, Just a couple of updates. The tail skid is fitted. Also, 0.8 mm diameter Brass tube was bent to represent the aileron operating levers, which are not supplied in the kit. Now its onto painting the flight surfaces, Mike
  2. Tap Permissions โ†’ Notifications.
