Everything posted by DocRob
Revell 1/144 Flower class Corvette
Fantastic work Paddy, I feared you would stall with this build earlier on, but now you are on a roll, besides the tiny platform desaster, which nobody would have noted, if you hadn´t mentioned it. The kit is not old, it dates back to 2016 Martin, I think you mixed it up with the 1/72 version from Matchbox, which layed keel in 1979. Cheers Rob
1:32nd scale Royal Aircraft Factory FE.2b
Me as well, I have the early model with some great figures, but didn´t have the guts to start this project for now. Cheers Rob
1/48 USTAR King Tiger Full Interior
Great work with all the detail FA Cheers Rob
Fiat Abarth 695- Italeri 1/12
I´m out as well, I find the Le Mans Abarth 1000 SP sexier. The price tag is a bit high, almost the same as the Le Mans Corvette. Inflation seems to hit Japan more than others. Cheers Rob
That´s why I have a huge disdlike for Italeri. Nothing against demanding kits, but a major player with access to modern production facilities should do way better. The kits are not worth their hefty price tag, which definitely is plastic premium, without premium product. Congratulations to Paddy @Paddy for guessing the new MFH release correct , it´s the Abarth 1000TCR, which is not so surprising, as I believe it shares the same engine with the Le Mans Abarth 1000SP 1/12scale Fulldetail Kit : 1000TCR Cheers Rob
I also try to guess, what´s next to come from MFH considering the pre release pics. Now that I re examined the pictures, after what you have written, you could be right. Cheers Rob
Oh no Paddy, you spoilt waiting for the news and made my Italeri kit a bin diver . Cheers Rob
Ferrari 412 T2 - The Last of the F1 Twelve Cylinder Cars - Model Factory Hiro - 1/12
The twelve cylinder block needs cooling and like with every F1 car, these coolers are huge. This part of the build was not particular difficult, but you need to have a proper sequence for adding the parts. My first steps were forming the air tunnel from two resin parts per side, gluing them together little by little, while checking, if the metal frame of the coolers sits properly. With the frame installed, I airbrushed these parts gloss black and added the carbon fiber decals after drying. Like usual, I worked from bottom to top and then added the framing decals, to have less visible borders. After letting the decals dry, the carbon ducts received a coat of matte varnish, as well as the etched grills from the coolers. The coolers themselves were installed then into the framing. They were airbrushed gloss aluminum, et voila. I only left the connecting pipes for later. Now it gets serious, as I need to prepare the first body parts, which means a lot of prep work, as I per usual try to paint all parts in body color in one go. Cheers Rob
There must be a way in between. The lower pic shows nice figure painting skills, but ships detail is waayyyy too crude. Cheers Rob
Thank you Carl, there will be loads of detailed subassemblies squeezed into the remaining space. The good thing with the kit, you can open the rear body shell to show most of the detail, albeit the exhausts for example are barely visible. Another benefit of the packed interior is, it is easier to hide the small hick ups, which at least I made with all my MFH builds. Cheers Rob
Thank you Paddy, I missed the D-Type unfortunately, I discovered it´s beauty a little to late. I believe the Jag will be a great building experience. The newer MFH kits are more refined and the open topped body gives you plenty of insight. I´m somehow addicted to MFH kits and get bored with others. Nonetheless, I will stray with other subjects soon, maybe a wooden fishermans boat or a tiny race plane, who knows. My MFH stash is growing wit the recent arrival of the Abarth 1000SP and the Le Mans Corvette C1, somewhere between Madrid and my place, hopefully arriving soon. I sometimes said, F1 cars are easier to build, but that is only partly true, the suspension is a bit thrilling and full bodied cars often offer more space inside for all the stuuf needed. My next MFH build will be a full bodied car for (relatively ) sure. Maybe one of the above mentioned, but there is also the Aston Martin DB4 GTZ or the Ferrari 250 TRI/GTZ.... Cheers Rob
Good to have it sorted Paddy. I always try to keep cut ends of metal on the working table and clean them away from there. Cheers Rob
Today, I finished the gearbox and rear suspension sub assemblies, but still need to touch up some blemishes. I have to remember, how I repaired smaller issues with the carbon fiber decals, my working method is gone with the old forum, but I think, it was touching up with a weathering pencil or a normal soft pencil. The construction around the suspension was delicate, to say the least. You always have to think about a working sequence, to get all these axles, arms and supports together in one go, without knocking off some coolers or others. The brake discs were sprayed with Zero Paints carbon fiber paint, which looks convincing in 1/12 scale. The rear wing support was a nightmare to build and I don´t know why, because while test fitting everything sat perfectly. I had to reglue parts, because the fit was poor now and the structural integrity was not given. When I had to build this again, I might cut the short cast pins and substitute them with brass rods, which hold the inner and outer (not yet installed) wing parts. Another mock up with engine and transmission: Cheers Rob
Nearly a shame to paint all the beuatiful brass. Do you anneal PE parts, specially those with rounded contours. It helps to make the brass less springy. You have to heat the part with a flame, until it glows dark red and turnes slightly blue in the process. Don´t overheat, it shouldn´t glow bright red. This reduces tension in the crystalline structure of the brass and softens it therefore. Cheers Rob
Very nice, seems to be a good kit and also in talented hands. Cheers Rob
You are doing a great job with all that PE, Paddy. Cheers Rob
I live on a small island and almost all goods delivered to my place come with airplanes, two engine passenger turbo props with a loading compartment, where it is not allowed to transport spray cans. There is a ferry as well, which explains, that there are a few spray cans available in some shops, but nothing, I would use. It is hard enough, to find vendors, who are willing to ship larger bottles of thinner or cleaner or bottles of paint, larger than 30ml. Downsides of Paradise . Cheers Rob
I have to live with what I can get on my remote place of the world. Spray cans are not available here, unfortunately. Cheers Rob
Flaking paint are an issue with these builds. Not alone because the paint chips so easily, but also due to permant dry fitting procedures, to figure the sequence of assembly. The combo of metal primer and Tamiya LP colors is good enough for that, but touch ups are neccessary often. Cheers Rob
You seriously help to get my Flower Class Corvette further delayed, Paddy . Cheers Rob
The most rewarding steps in MFH builds are called cash in phase by me. That´s when all parts are cleaned up, primed, airbrushed, finished and ready to assemble, then the fun begins, of course always spiced with some obstacles. The rear suspension and gearbox are nearly done. I sprayed a layer of Tamiya LP-21 matte clear onto the carbon fiber decals and assembled the prepared parts according the manual. Quick mock up with floor pan and engine: Cheers Rob
1/35 Italeri Ostwind, Recycling old kits
No 3D-printing, no PE, I´m shocked Martin . Nice dive into retro modeling. Cheers Rob
Thank you Carl, due to the great fitting decals, it was not so hard, but it takes a lot of time and patience. Cheers Rob
It´s a time consuming process, preparing the parts, metal primer, color base coat, decal application, several coats of Mr. Mark and working the decals to lay perfectly. With all the in between drying time, it takes a while. But you are right, it´s a rewarding task, once the satin finish is on. Cheers Rob
The gearbox and rear suspension consists of delicate parts and some of them are covered with either embossed heat protective foil or carbon fiber decals. The foil needs to be cut by hand, but there are paper templates, In case of the rear wing supports, I decided not to use the templates, but to apply the foil onto the part and cut around with a fresh blade. It is so easy to destroy the embossed character and it seemed to be the easier way. The Carbon fiber decals are printed by Cartograph and fit like a glove, which is very helpful, as they have to contour around some delicate shapes. I applied them with warm soapy water and followed with Tamiya´s Mark Fit Strong for several times and used different tools to lay them down. On the pic, they look a bit bubbly, but that is due to LED lighting and looks better to the real eye. Tomorrow I will coat them with some satin varnish. I also assembled some sub assemblies, like the shock absorbers and a air cooler. Cheers Rob
