FINISHED | ICM 1:48 HP.52 Hampden B.Mk.I - Review and build !
  • Author
Not everything is a fairy tale..
As I continued with the painting process, I added the engine and its respective covers so that I could apply the camouflage colours.
Well, the fit was not what I had expected, not because of any fault in the parts or moulds, but rather due to the modeller's own experience. As I had used super glue to join the parts together, removing them would have caused damage that I did not want to repair. Therefore, I decided to fix the joints and correct the fit issues with the assembly already in place.
Using super glue mixed with talcum powder, I concealed the seams and sanded them with a small 600-grit sanding block.
Finally, I re-scribe the panel line and applied the camouflage colour.
With this difficulty overcome, I moved on to weathering the upper camouflage using my usual approach:
I apply patches of the base colour, either lightened or darkened, and then work on the centres of the panels, rivets and panel lines individually. If, in the end, I feel that the contrast is too strong, I tone it down with the base colour.
At this stage, I am only working on the brown areas of the camouflage.
And then, the green camouflage patches
As always my big struggle is to know when to give the job as concluded...
  • Author
On 8/25/2026 at 5:10 PM, Belugawhaleman said:
Looks amazing😀
Thanks for your feedback!
On 8/25/2026 at 6:40 PM, Martinnfb said:
Clean and crisp. Joy to follow.
Martin
thanks !
and today's update!
It's all about decals !
The ICM decals feature very good definition and shape fidelity.
On the decal sheet, they appear slightly thick, and this characteristic can sometimes make application more difficult.
I started by trimming the carrier film as closely as possible in order to minimize the silvering effect once the decals were applied to the model's surface.
The decals react well to water, showing no resistance when being released from the backing paper and transferred onto the model.
The whole process was smooth and straightforward. The registration letters (P-EA) were trimmed to the minimum amount of carrier film possible in order to reduce any potential silvering.
Applying them with Micro Set makes repositioning much easier. Once I felt the decal was correctly aligned, I gently rolled a cotton bud over it to remove any trapped water or Micro Set beneath the decal.
Overall, the final result was very positive and stress-free, as the decals have enough flexibility to conform to the model's surface details, whether rivet lines or panel lines.
The use of Micro Sol after application helps soften the decals and allows them to settle more easily into the surface detail.
Some decals were applied with the carrier film intact and, after application, no silvering was visible. From my visual inspection, they appear to be perfectly integrated into the model's surface.
In this case, the combination of Micro Set and a glossy surface greatly helps to eliminate this tendency.
One point worth mentioning concerns the fuselage roundels. In my opinion, they are slightly translucent, which is particularly noticeable in the yellow and white areas of the roundel. However, this is by no means a serious issue or something that would make me immediately consider using an aftermarket decal sheet.
If suitable replacement decals are already available in the spares box, then all the better. If not, these are perfectly acceptable.
For now, I have left the decals to settle under a coat of DACO decal softening solution.
Tomorrow I will return to the project and continue with the stencil decals on the underside of the model.
thanks for watching!
  • Author
Final Stretch at Full Throttle
Since applying the decals and dealing with the glossy carrier film, I came to the conclusion that the film can actually be removed, in a similar way to Eduard decals.
However, I did not remove all of it. Due to their very small size, I decided not to touch the service markings and warning stencils in order to avoid damaging them.
Concerned that this glossy layer might cause a silvering effect, I applied another coat of gloss varnish to seal those decals. I was pleasantly surprised by the final result, with no sign of silvering and the decals blending perfectly into the paintwork.
With this stage completed, I moved on to the weathering process. From the outset, my intention was to concentrate the weathering around the engine areas, while keeping the rest of the airframe relatively well maintained.
The weathering was carried out using oil paints (black, brown and grey), applied section by section and allowing the appropriate drying time between applications. I also used a highly diluted mixture with Lamp Black to darken selected panels, creating subtle points of visual interest across the wings.
Still not entirely satisfied, I decided to use AK gouache pencils, applying them very selectively and carefully blending them on the fuselage, as well as on certain areas of the wings and national insignia, helping to integrate the latter more naturally into the finished model.
What remains is the removal and correction of the masking on the transparent parts, the attachment of a few small details, navigation lights and antennas before I can officially call the model finished!
For now, here is its current state of the model, already with the main gear attached:
thanks for watching !
Now that looks great, if mine turns out half as nice as yours I will be happy.
Dennis
Edited by Spitfire
  • Author
On 9/13/2026 at 8:52 PM, KevinM said:
Looking very Nice Ricardo 😉
thanks KevinM!
On 9/13/2026 at 9:43 PM, Jeroen Peters said:
Lovely in every sense. Love the camo and contrast in the colours.
Hi Jeroen ! Thanks!
Dennis
i'm sure that it will be ! if you need any additional info, let me know!
The Finish Line
Good evening!
Finished! Complete! Concluído ! Acabado!
This stage, when the model is finally standing on its own undercarriage and all that remains to be attached are the small details, still gives me an enormous sense of satisfaction and achievement.
The Hampden is now complete, and for quite some time I have been thinking about how best to express what I feel upon finishing this model.
It is a large model in terms of size (around 50 cm (19.7 in) wingspan and 40 cm (15.7 in) in length), and I am already wondering where I am going to store it. However, after taking the final photograph, I simply sat back and admired the finished model.
For me, this build represents a new chapter in my modelling journey.
During construction, I became aware of how easy the parts were to assemble and glue, and of the precision of the fit throughout.
The supplied templates for the clear parts greatly simplify the masking process (around 60 masks in total).
I made one mistake not directly associated with the model or the mould : I chose to leave the landing gear until the end , knowing there was a high chance of damaging it during the painting stage. Looking back, my advice would be: prepare the landing gear and follow the instructions, protect it carefully, and take extra care when handling the model.
The panel line and rivet detail is very appropriate for the scale and benefits greatly from a detailed paint job, although the final effect will always come down to personal preference.
The decals present no difficulties and conform very well to the surface. I applied them over a coat of gloss varnish and sealed them afterwards with another light coat. The glossy carrier film protecting the decals can either be removed or left in place. I removed it out of curiosity on the larger markings and left it on the smaller ones and once covered with a matt varnish there was no visible difference.
As for me, I am completely won over and genuinely impressed by the quality of the fit and by the minimal amount of putty required to blend the joints. The extremely tight tolerances of the parts and the quality of the moulding contribute enormously to the overall building experience, making assembly both relaxing and genuinely enjoyable.
 With this model, ICM demonstrates exactly why it is regarded as one of the leading manufacturers in the modelling world today, making this subject an unquestionable choice for any modeller with an interest in aviation.
Without any doubt, this is a complete and dependable package, and I can wholeheartedly recommend it. My opinion is, of course, based on all the photographs published throughout this build thread, which I hope help to illustrate and support everything I have written here.
I'll leave you with the final photographs!
My sincere thanks to ICM for providing the kit for review and build and of course, it's a highly recommended model!
Now it is time to tidy up and clean the workbench... and, of course, find a safe box to store it in! 😀
p.s. in the meanwhile, a hour of work and minus a cloth storage box, a safe shelter was built!
My truly and sincere thanks for following me in this adventure ! my humble thank you!
I have found Ricardo and think the quality and assembly of ICM's AC is on par to Tamiya with a slightly lighter in the pocket book effect.The subject matter is becoming more of interest in their line of AC over the staples of Hasegawa and Tamiya with ICM producing multi-engine AC the other manufactures forget about in 1/48 scale.The build looks spot on in my book great looking AC!😉
Fabulous build, and finishing it looks great, and it is great to see some early WW2 RAF subjects coming out in modern kits, so a thank you to ICM.
Dennis
Your satisfaction is well earned, your Hampden is a beauty and your building log, which has somehow escaped my attention due to a summer hiatus is very thorough and well written, congratulations.
