  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
I was going to say this thing fought me all the way but in truth i think i fought it 🤣 My interest in the build was blunted by a series of awful decals., no ones fault after all they were cartogragh but age wasnt on their side and patience wasnt on mine.
Looking at the pictures the gun mount needs a pin wash. overall its turned out OK if you dont look to close which cameras always do 😉
Despite your decal issues, she turned out really nice, Paddy. I have several WNW its in my stash and hope the decals will hold up until building time, but I read logs, where other builders had problems with WNW decals.
I use fishing line for rigging. When back home, i will look for the diameter. Using eyelets and tubes with an inner diameter of 0,3 mm, looping the fishing line through the tube, the system is self tauteneing after a little pull on the loose end. A drop of CA seals the end and the rigging is giving the whole plane a lot of strength. Believe me, I needed that with the huge WNW AEG night bomber, I once built.
  • Author
Hi Rob
The rigging line here was 0.18mm fishing line through 4mm bore brass tube. the eyelets were 0.2mm tinned copper wire wound round 0,5mm wire
The whole lot was tensioned with heat from a soldering iron. I did but some Gaspatch turn buckles but they didnt really suit what i was trying to do.
sweet🤓
Wow, this came out great! Nice job!
Just went back through your log. Holy cow, you have a lot of patience to deal with those decal issues. I don't want to think of what I would have done in your situation. Congrats on persevering and getting through it for a nice finish at the end.
Edited by Landlubber Mike
