October 1Oct 1 Author Hi all,A few more bits of rigging added:Aileron control cables.Outer flying wires.Tail skid control cables.Rudder control cables.Elevator control cables.Also added the 'Hale' bomb with bomb rack.Over wing bracing pylons.Wheels.I felt cementing the external control levers for the elevator into recesses in the fuselage sides would not be strong.They may not have been good enough to withstand the tension of the tightened control wires. when fitted.Therefore, I drilled out the centres and fitted a 0.5 mm diameter Brass rod.The locations in the fuselage sides were also drilled through.Once pre-rigged with turnbuckles the levers were secured into the fuselage with thin CA adhesive.Just a few more bits to do on the aircraft model then it's onto the figures and base,Mike
October 4Oct 4 Author Hi all,Kellerkind Miniaturen RFC pilot in sweater (54/067) and RFC pilot (54/026).Mike
October 14Oct 14 Author Hi All,The RE.8 model is now finished.I'll post photographs later in the Completed Works page.Thanks for your comments and support throughout this build,Mike Edited October 14Oct 14 by sandbaggeruk
