Revell 1/144 Flower class Corvette
This is my first attempt at a ship. I would guess i started building about 55 years ago so quite a miles stone for me . I have to admit i know nothing about ships other than the basics you pick up on in life so all i can do is apply general modeling principles and steal other peoples ideas from the millions of builds on the Web .
My biggest problem will be the scale, i like to add nuts and bolts and wiring to a 1/12 car, its hard to see what i can add to this kit other than PE. Normally i avoid PE on builds due to its two dimensional nature when i am building three dimensional models but in this scale PE could actually work quite well as 1/144 parts like ladders etc would appear flat anyway ?.
Would you believe I found a 12-minute documentary on WWII Ships railings on You tube
Railings on ships were mostly posts with wire strung between them and were called life lines. Vertical posts varied from i section castings and extrusions to just round steel posts. These posts were 1 inch dia and strung with either ¼” or ½” wire or chains. So the first problem is the posts on the Snowberry would need to be .007” (7 thou) and the wire about 2.3 (thou). In terms of metric which most plastic and brass comes in that’s 0.2mm vertical strung with less than 0.1 of a mm. Bearing in mind the posts would need to be drilled to take the wire it’s hard to see how you could get the posts any smaller than the kit posts which look huge.
So that’s not going to happen.
The kit railings are 0.8mm or 115mm true scale ( 4.75 inch ) so nearly 5 times over size. I think in this tiny scale it’s going to be compromises all along the way which is a shame as I hate out of scale things where for example you have a porthole to scale and a railing above almost half the diameter of the porthole
I will wait and see what the PE looks like when it arrives later this week from Korea. I think I need to develop a completely new mode from my std 1/12 mode these days and build to create the right effect/impression, so things look right rather than are right.
Flower Class Corvettes were built for coastal work. They were never intended too cross oceans, they rolled, were flat out at 18 knots and were not weather proof, originally built for a crew of 50 most were carrying over 80 by the end of the war. Cramped, Cold, Wet, poor food, uncomfortable to the extent some people never got over their seasickness, they were a miserable place to be.
300 were built . 22 were torpedoed by Germans but they sank 44 U-Boats. however it was not about scores, the real victory was how many merchant ships made it across the Atlantic thanks to these small ships, not how many U-boats never made it home..
There were two versions of the flower class, early and modified, identified by the mast being in front of the bridge or behind, this will be build of the later one below with the mast behind and roughly 200ft long and 1000 tons.;.
All i have done at this stage is tape things together to make sure the basics fit. This is just 4 parts but but i need to get this right, straight and true as its the foundations of the whole build.
One other pet hate of mine is Revell boxes so the first job was to convert it to a top opener so you can find parts without having to tip them out all over the place
  • Replies 68
  • Views 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Here it is with the kit parts fitted and the PE ledge all round the outside. Soldered up PE radar tower. You have to fold the windows and railings into a hexagon so each fold angle is the same and t
  • Yea thanks Rob i did anneal the brass for the funnel to take the spring out of it but i only took it to blue, nowhere near red :-) I bought a dspiae roller kit for the funnel as i didnt have anything
  • Bought a proper soldering iron with a temp control and fast heat up 15 seconds to 400c :-) I have never soldered PE before because its always been small parts in 1/48 cockpits etc, this is about 1 inc
Posted Images
  • Author
Despite my best efforts to get the basic hull correct I have been thwarted because the 2 halves of the hull are not quite symmetrical. There is a central bulkhead that locates in slots each side of the hull and this forms the vertical wall between the forward and aft top decks which are on different levels. Unfortunately, this bulkhead doesn’t sit square so the decks don’t butt up against it properly. I cant see an easy fix at the moment but it might not show once the superstructure is in place on the decks. I dont want angle the bulkhead and i dont want to trim the decks so it might just be a case of fill it
what i have done is got rid of the seam /join between the 2 hull halves. Ones its Matt black it should disappear completely
Edited by Paddy
Sailor reports on board, Paddy. Shame with bulkhead fit. I will peep over your shoulder, as I have the same kit with the big Pontos set. I will add Ion figures to mine. Other than you, I built a few ships over the decades, but only one recently. It was the USS Arizone in 1/350 and you are right about needing to adjust to small scales.
When I was a teenager, I built the 1/72 Matchbox Flower Class Corvette and equipped a RC set, but these were different times and different quality standards.
If you like venturing into ships, you should also try a wooden sailing boat. I built Vanguards Duchess of Kingston as my first and enjoyed the build immensly. I stalled with the rigging though, which waits for me to finish it.
If PE ladders or railings are to flat for your liking, you could cover them carefully with CA or PVA glue. After curing they look a bit more 3D.
  • Author
The bulkhead was lose in the box, now i have found its sprue i can see some of the problem
Twisting it back where it should be helps the front deck a small tapered slither of plastic card sorts the back deck.........for now
  • Author
I hope i haven't bitten off more than i can chew Martin. The kit would be pretty straight forward but the PE could be a step too far. The problem is you have to shave off 95% of the detail from the kit parts before you can add the PE and at that point there is no going back and PE can get lost/dropped , ping off into oblivion or snap when folding and so on.
  • Author
6 sheets of PE approx 8" x 4.5"
assorted turned brass fittings, depth charges and gun barrels , also wooden deck and some rigging line not shown
And where i am now, This is the last chance to finish this as a large kayak before it becomes a small ship
First job now is to fit the portholes. These are not listed in the instructions and the finished Portus model doesnt show them but there are 50 on the PE sheet.
I am going to follow closely the You tube build as to be honest, i know no better and he has fitted the portholes.
The Flower class is such an iconic part of Canada's navy from WWII.
That's quite the upgrade set you've got there for it.
I know for the older 1/72 Matchbox kit, Great Little Ships made so many upgrades for the kit that if you bought them all, pretty much all that was left of the kit was the hull. Hopefully that not the case here.
  • Author
I have read a few write ups on the 1/72 and it's supposed to be a pretty poor model so i expect it needs all the help it can get 🤣
  • Author
Bought a proper soldering iron with a temp control and fast heat up 15 seconds to 400c :-) I have never soldered PE before because its always been small parts in 1/48 cockpits etc, this is about 1 inch square
I have been playing with the PE while i wait for paint to dry on the hull . i was going to do a uniform pattern like others but then i thought, why would a ship have panel lines ? The hull is constantly jet washed so i would imagine general wear to the surface so i have gone with this as a base and its a lot more subtle than other build on the web.
Edited by Paddy
Paddy it's recommended to lightly sand your PE with 400/600 sand paper just be sure all is flat helps the primer stick better and I use 1500 MrSurfacer it works.I am thinking of doing the Heavy Cruiser Bulcher and have never done PE hatches/Doors will add hours for sure.I would not worry about your ability here just realize some where down the line a break needs to be taken and to build some thing else that's quick.😉
  • Author
All advice gratefully received , I did used to do soldering at work but it was using a gas torch on an industrial scale not fine work with an iron. As you save Kevin its easy to lose many hours playing about with PE. I am not a huge fan of most of it as its very 2D flat but it works in this case as walls a are flat 😆
  • Author
This build is a real departure from the safety of what I have learned over the years, Its quite exciting and I look forward to getting on with the build when I am doing other things. I need my brain working at 100% because trying to overlay the Revell instructions and the Pontus “instructions” ( i use the word loosely) is mind boggling, mainly because Pontus have replaced about 50% of the Revell parts so the Revell instructions are meaningless, and partly because a lot of the Revell parts have Pontus parts added so none of the location points match. This compounded by the lack of Pontus instructions on specific positioning of parts, for example does a wall sit on the floor or butt up against the side of the floor ? and so on. Painting is also a conundrum as most floors are dark grey and walls are white and  as most superstructure in more than one level you have a grey white grey white sandwich going on with very small parts which means these parts have to be painted before assembly, nearly all walls are different colours either side. I have mixed the colours for the hull , The white is  basic insignia white, the blue is a mix of azure blue and light blue and the green is sky and interior green ( all basic aircraft colours)
I did order the correct colours, but I couldn’t make head nor tail of the paint. These were life colour paints ?  I looked them up on Google and the answer was use distilled water to thin them but that made mine coagulate instantly. I tried Tamiya thinners, Mr colour levelling thinners , Acetone and IPN, all made the paint go into a rubber goo. It took me an hour to strip and Clean the H&S and I lost patience with the paint.  The odd thing was I opened another new bottle of this paint and there is like a rubber goo in the bottle. I fished some out on to a cloth and there was what looked like hairs in the paint but these were actually like rubber hairs, strange. Any way I used the bottles to colour match some self-mixed paints as above.
The only disappointment so far is not really being able to get on as every part has to be cross referenced to two sets of instruction to see if it’s used or replaced, there are literally thousands of PE parts all randomly numbered on 6 sprues and it can take 10 minutes just trying to find the right part, part number 10 might be on one sprue and No. 11 on another, next to part 789.  So it’s hard to settle down and get on with things and make headway.
I always have issues with instructions; they never seem to be written by anyone who has actually built the model ?  A huge advantage would be if Pontus  supplied instructions for the complete build with Revell and their own parts so you didn’t need to merge 2 sets of instructions in your head.
As it is there is a great on line build as I previously mentioned where a guy has worked out the order of folds on the complicated PE parts for you and  clearly shows the mix of parts for all sections……………but even then you need to double check as  we are all fallible and he discarded the wooden floor on the bridge saying he had never seen a wooden floor on the bridge of a Corvette……he has now
                This afternoon i got an email from the paint supplier who tells me he sent the wrong paints....He sent Eastern approaches scheme instead of western approaches. ...... To late now so this is now officially an eastern approaches ship dealing with north Atlantic convoys to Russia and not western Atlantic to north America. Obviously if i had know anything about ships i would have noticed....much like a ship builder might not notice the wrong factory colours on his first motorcycle Anyway i am not changing it now even though i found the paints unusable i did use them to colour match.
Edited by Paddy
Well Paddy that is part of ship building and have heard others mention some of the same issue on Pontos instructions..I have Eduard for the Bulcher and even there instructions are requiring some study.I do think some kind white on interior walls will be the color just like in tanks reflective to the eye even dim red light works.I build in module assemblies Forward SS,Rear SS,main guns and then always thinking inside out....take a piece build it, modify it and set it aside then final assembly.😉
Oh what's the stand/base? that needs to be decided now.
Edited by KevinM
  • Author
Thanks Kevin, the base will be the kit thing, this build is very much a feeling my way rather than a shelf centerpiece. I am very fussy about what i keep for display and what goes in the bin...
People find it odd that i don't keep much of what i build but space is at a premium and its rare i sit back after a build and think, yea i'm pleased with that. The plus side is it drives me to keep going and do better. I have a reasonable size glass cabinet, it holds about 8 x 1/12 cars or 16 x 1/9 motorcycles or a combination and usually if something makes the cabinet ,something else gets the boot.
To me kits are like jigsaws , great fun to build but a bit pointless and a nuisance once built....
100% agree with your method of building a couple of dozen sub assemblies and assembling on to the hull later 👍
Edited by Paddy
  • Author
Painted a few small parts last night., i made a bit of a mistake in using a grey primer which is too close the the insignia white top coat so its hard to see what you are doing
There are quite a few railings with canvas sheets over them as spray protection i guess. Not sure if the canvas would be White washed or more like doped linen with a brown tint , if i just do them white they look like sheet steel as there is no contrast with the rest of the superstructure.
I have put the H&S away now and resumed my search for Badger Krome spares. I know i am hyper critical and tend to bore people but i did work in product design and there are basics in the industry......As a whole it does an excellent job, i guess if you were a finger nail artist etc you might not find any better but i dont like the ergonomics of the thing, its not nice to hold or operate, i can quite explain why but i think it needs to be a bit thicker/substantial , maybe better for a woman's hand , it looks great in chrome and is thus easy clean but it needs some rubber pads or knurled areas to hold it firmly, its a slippery bugger The bowls are two narrow at the bottom making them difficult to clean, and the lids are a nightmare being metal on metal they are not user friendly to slip on and off as they stick if not absolutely square when positioned. Finally the bowl is to near the trigger and gets in the way of your finger.
you cant see it in the picture but under my thumb on the badger is a plastic rest so you can grip the body. You cant Fault the operation and results of the H&S but its capabilities are way more than even the best modeller would need and as such it has its annoying idiosyncrasies. As i say i am sure its perfect for fine detail work with Graphic artists but it carries a lot of baggage for a model maker who needs a small spray gun
Edited by Paddy
We seem to have quite some parallel approaches and modus operandi, Paddy. Like you, I loose interest, when a build is finished, the build itself is the satisfactory part.
I used Lifecolor a lot in past years and liked them a lot, but can´t remember what I used for thinning. It was definitely not distilled water, I would have guessed it was leveling thinner or Tamiya acrylic thinner. Unfortunately the knowledge is gone with the forum crash.
A while ago, I made a quck search for the correct Flower class Corvette colors in the North Atlantic and went blank, other than generic paint names. I would be very grateful, if you could write the correct Lifecolor equivalents.
I love the H&S Infinity, it´s my go to airbrush since some years. I mainly use the Giraldez edition, where the trigger is even nearer to the cup, but the trigger has a sharp front lip, which operates quite well with my clumsy fingers. I don´t lay my fingers around the trigger tip, like you though, but, if it is really interchangable, the Giraldez trigger might be an improvement for your H&S Infinity.
Let me know, if I should test interchangeability for you.
Above Infinity and the lower one is the Infinity Giraldez edition.
A better view of the trigger with the bigger cup. I can handle it very well.
  • Author
Hi Rob
Probably the best reference is the lifecolor boxes as they give you the paint numbers and colours, bear in mind thought they give you hull red in the western approaches and Corvettes form Canada had black hulls.
61Lp5AkOVkL._AC_SL1500_.jpg lc-cs34_1b_6b3bba63-1e11-464c-aaa8-7ba47d46a20e.webp
Edited by Paddy
Looking good Paddy the linen for me have to be tinted.I have never used a H&S airbrush have been a Badger guy for over 50yrs now they are rugged and dependable for my needs.I use the Renegade line interchangeable tips(fine) and some of the Patriot line one for gloss/primer the other like the Renegade except the Patriot has the upper cup.😉
Boy I just cannot do that fellas I have builds going back 40years and you can see one's development over time.I have maybe over 300+ saved guys.......
Like Rob, I love the H&S airbrushes and have never had any problems with gripping them or operating the trigger but I don't have particularly large hands. Everyone has their own favourites and it's just horses for courses as to what will work best for any given individual. I've never tried Badger as they are simply hard to get hold of where I am, whereas I can easily get H&S and more importantly the spares
  • Author
I spent 4 hours this sunday morning and got nothing done to show you
Its the age old problem of holding the bits of sheet brass (PE) edge to edge at a perfect right angle and joining it.DSC_1057.JPG
This is 3 parts i soldered. Assembled its about 12mm x 10mm so under 1/2" on the long side. There are 7 angled ribs to add and 9 corrugations to go inside the 9 sections created by the ribs .....so 19 parts on this bit no bigger than your thumb nail. Because the brass is only 8 thou" thick the heat spreads instantly and i cant add any more to the above without activating the solder already holding everything in place. CA sort of works but looks awful , again the ribs go on edge and CA gives no strength. I need to make another of these and a dozen more of other areas of the ship....
My next plan is to see if i can replicate the above in plastic card which will be a lot easier to join/glue.
I thought MFH models were hard but this is 10x more difficult. a real challenge..... Actually its not difficult, its just i don't understand the destructions and I dont know how to work with PE.
I am no use on that Paddy never soldered sheet brass before done some welding in my yuth.😉
