Revell 1/144 Flower class Corvette
I suck at soldering ... But, one thing I have tried when I had to solder together multiple thin parts, was to assemble them (maybe using some spots of PVA glue would help hold everything together ?), dab soldering paste on all the joints, and solder the whole assembly in one go with a hot air gun (the Proxxon one works like a cham) ...
HTH
  • Replies 68
  • Views 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Here it is with the kit parts fitted and the PE ledge all round the outside. Soldered up PE radar tower. You have to fold the windows and railings into a hexagon so each fold angle is the same and t
  • Yea thanks Rob i did anneal the brass for the funnel to take the spring out of it but i only took it to blue, nowhere near red :-) I bought a dspiae roller kit for the funnel as i didnt have anything
  • Bought a proper soldering iron with a temp control and fast heat up 15 seconds to 400c :-) I have never soldered PE before because its always been small parts in 1/48 cockpits etc, this is about 1 inc
Posted Images
  • Author
So far i have spent more time disassembling than assembling. the beauty of PE and metal parts is you can just dump them in Acetone and it strips paint and super glue instantly and you are back to original parts.
My problem was that the wooden decking fits like a glove to the plastic deck, so far so good. the fence that goes round the deck is 8 parts that join to form 1 piece round the deck...however they fit like a glove around the wooden deck but they need to fit on top of the wooden deck .Some parts are folded and if you have a U section its hard to reduce its width. Answer is to just make new parts so i have trimmed half a mm of the outside edges of the wood all round to reveal half a mm of plastic deck and now i am remaking parts of the fence in sheet alloy however i have just looked on line and Albion alloys do 8" x 4" sheets of brass at .25mm thick which would be perfect so0 a trip to the model shop is required.
I can see i will be making a lot of parts for this as folding half a dozen PE parts is always going to increase the risk of a creeping error.
All good fun
Edited by Paddy
Looking good. As for the heat creeping from soldering, maybe you can make a heat sink with a spring loaded tweezers. "Clamp" the tweezers between the work you're doing and the work you've already done and it might just stop the heat from radiating across the whole piece, or at least slow it down. It might work. 🤷
Edited by jep1210
You seriously help to get my Flower Class Corvette further delayed, Paddy classic_biggrin.
  • Author
Don't take too much notice of me Rob. I am not a ship builder, i have never worked in this small scale before, i even avoid 1/48 these days let alone 1/144.
I haven't ever done this amount of PE before, most of my problems stem from not understanding the instructions 😊
This is where i am at now i have tidied things up a bit and made some new parts.
I think the key here is working out what PE is there for the sake of it and what is actually needed to enhance the model for example there is a PE sheet on the under side of the top deck floor or the ceiling of the lower passageway ?. The fencing on the sides and back should be poles and canvas. The PE makes it look like sheet steel, on reflection i think the kit parts would have been better as they are detailed both sides. PE is good for fine detail like ladders and many other small parts but i am not sure it does the basic structure a lot of good. Anyway it's fun so far and thats what its all about. I am already considering building another OTB ...
Edited by Paddy
  • Author
ok cancel the above i think, there are some kit parts that go on the PE fence i thought looked plain...they are just not on the instructions.😒
  • Author
Soldered up PE radar tower. You have to fold the windows and railings into a hexagon so each fold angle is the same and the ends meet up which is really trial and error
its quite small 😆
You are doing a great job with all that PE, Paddy.
Great work so far. The pic of the radar tower on your finger tip really puts into perspective how small things are.
  • Author
I think this is as far as i can go with the bridge. I ran into problems with the 20mm Oerlikon guns which should be all PE however i found the PE kept snapping when folded . What we have here is a mix of PE, kit parts and scratch ammo drums etc. This is probably where 3D print would beat 2D PE hands down.
I am not sure at this stage what to do about weathering ? You see lots of these builds with lots of rust but apart from being quite clever artistically i dont see any real point unless you are going the whole hog with a seascape /diorama. Consequently i am leaning towards a museum type finish with pin washes etc to highlight detail.
Edited by Paddy
  • Author
I managed to roll the PE for the funnel and its turned out really good. Nearly all the PE here is extras not included as plastic parts in the kit. Its pretty straight as it mostly folding up boxes . Of course i have lost an important part which is a small desk with three gauges on that goes over that square hole in the deck on the right.
Its not hard to scratch another but its bloody annoying😒
Nearly a shame to paint all the beuatiful brass. Do you anneal PE parts, specially those with rounded contours. It helps to make the brass less springy. You have to heat the part with a flame, until it glows dark red and turnes slightly blue in the process. Don´t overheat, it shouldn´t glow bright red. This reduces tension in the crystalline structure of the brass and softens it therefore.
What he said!
  • Author
Yea thanks Rob i did anneal the brass for the funnel to take the spring out of it but i only took it to blue, nowhere near red :-) I bought a dspiae roller kit for the funnel as i didnt have anything to roll it with, this is the top of the funnel rolled ready to fit
Another useful item for this build is the PE glue...FLEXY PE 5k CA , it a CA super glue but it has a degree of elasticity so parts glued can be carefully bent without the joint snapping like normal super glues,. Its also a super strong glue about twice as strong as normal CC.
These three items were super expensive but with tools that last a life time its worth buying quality
2x Tamiya PE folding pliers and 1x side snips
l
  • Author
Brass is nice, grey looks better for detail
Not looking forward to the pin wash. It would be easier if i gave it a gloss coat i think, The panel line washes won't run on this mat.
  • Author
I had to go to the doctors last week. I had a hole appear in my foot, right on the ball ... I was worried it might be the start of an ulcer as it was really painful and i couldn't put any weight on it. Any way the nurse said i had probably stood on something, she thought it was a puncture wound but it was all clear now, keep it covered. I was doubt full because this was "really" painful.
Any way this morning i went to put my sock on and it caught on something sticking through the bandage.........
0.5mm x 9 mm it was so far in you couldn't see it , it's an off cut of a homemade motorcycle spoke from my last build...... Anyway i can walk again, ist a miracle....the things we go through for our hobby
Good to have it sorted Paddy. I always try to keep cut ends of metal on the working table and clean them away from there.
  • Author
Todays dilema. This is the gun platform from Pontos PE, it completely replaces the kit parts
Nice as it is its beyond my skills. maybe 30 years ago with younger eyesight and dexterity but i took one look at this and its not going to happen
Around the edge are brackets that hold ammunition for the main gun like the sackville in Canada
s024.jpgThere are 22 of those and the PE is 1mm in the vertical and each holder is 2 parts, the longer part folded into a z shape
Seen here along side the kit part
I cant do this, i dont think i could even produce a blob of CA small enough to join the two PE parts together let alone hold them in place and then fix them to the base.
{906D674B-00A5-4BAE-9DA8-C7781E129C38}.pngthis is someone else's build i found on the Web using just the kit parts , It's quite incorrect and of course the ladders and railings are way over size.
My mission now is to try and recreate some thing to scale thats acceptable using a mix of parts i think.
Edited by Paddy
There must be a way in between. The lower pic shows nice figure painting skills, but ships detail is waayyyy too crude.
  • Author
I really am stuck now. i had to shave the detail off the kit gun platform to get the PE base to sit flat and cover it so the kit option has gone and i cant do the Pontus option :-) I could maybe bodge the PE parts and just have a few ammo holders but that would spoil the whole build for me. I can have 999 excellent points on a build and 1 bad point and the bad point will always stand out.
The kit part had 28 ammo holders, the PE gives you 22 and the Sackville pictures seem to show about 18 . I also notice that there are very few flower class Corvettes with the same layout so its back to research and see if i can salvage this.
Edited by Paddy
The pic of the painted stack almost looks like one of those CAD images you see companies use to promote their products.
For the ammo holders, maybe try PVA glue to put the parts together? It'll give you more working time and let you get the amount of glue needed.
  • Author
Unfortunately i looked at several others assembling these parts on you tube today and they have no problem at all which makes me realise the problem is me. they do however show these minute pieces of PE fitting into slots in the base but on mine the slots are not big enough for some reason. Even squashing the tang on the parts with smooth pliers i cant get the tangs anywhere near into the slots. I think this will have to move away from an accurate model of a Flower class Corvette to a generic escort ship and i will have to provide ammo in a rack or make some other means of storage. the Fence round the gun platform is also causing me problems as its just flat PE posts strung with rope or in this case it will have to be a very fine black fishing line , maybe 2lb breaking strain. I think i might try and remake the posts in brass rod to give them rigidity as you can imagine a little thin strip of PE has zero integrity and even less surface to apply glue . I honestly think i could bend it by blowing on it let alone hanging a thread on it 😂
Edited by Paddy
