Revell 1/144 Flower class Corvette
  • Author
I didnt really expect to be able to assemble the Anchor winch in all fairness but i gave it my best shot. It is very small, even under my 3x magnifier i cant see it enough to be able to do anything with it.
dsc_1153-jpg.195562
These are the parts for one gear cluster. My problem here was the shaft is .027" or 27 thou and the holes on the gears and washers are .022" or 22 thou and i cant hold the shaft to turn it down or the washers to open them up. without them collapsing
dsc_1156-jpg.195563
I think i will have to use what i can to upgrade the kit part
dsc_1157_01-jpg.195560
Its not ideal but to be honest while it would be great to use the PE i have to accept my limitations and also the fact that when assembled , most of the detail will not be visible to the naked eye without some form of magnification and to be fair the rest of the model wouldnt stand up to that sort of scrutiny anyway .
  • Replies 68
  • Views 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Here it is with the kit parts fitted and the PE ledge all round the outside. Soldered up PE radar tower. You have to fold the windows and railings into a hexagon so each fold angle is the same and t
  • Yea thanks Rob i did anneal the brass for the funnel to take the spring out of it but i only took it to blue, nowhere near red :-) I bought a dspiae roller kit for the funnel as i didnt have anything
  • Bought a proper soldering iron with a temp control and fast heat up 15 seconds to 400c :-) I have never soldered PE before because its always been small parts in 1/48 cockpits etc, this is about 1 inc
Posted Images
  • Author
Thanks Martin thats really strange because i ordered that vey part from swordfish about an hour ago ;-)
It's a bit defeatist but i just dont have the manual dexterity in my fingers i used to have. As 3D print becomes more affordable and the files are readily downloadable i would imagine PE will die out pretty fast. The whole idea of making 3D objects from 2D sheet is a compromise with corners and curves and tapers.. With this particular PE i would say to anyone else you need to anneal any part with more than a 90 degree fold as the brass tends to snap very easily.
Thanks again
I remember scratchbuilding the foc’sle winches on the venerable - therefore much reworked - 1/600 Airfix SS Mauretania …
It is the time when I decided to focus on 1/32 aircrafts rather than teeny weeny liners kits. I wonder if this led to that 🤔 ?
  • Author
It won't have gone unnoticed that my prefered scale get larger as my age get larger 😂 I am currently at 1/12 cars and 1/9 motorcycles. 1/144 is a step too far for me .
Thanks again
Hey Paddy even the SF product is better than what PE would of produced so no foul in my book.I assembled the capstans for the Blucher last night so crude was thinking this morning ...any 3D?🤔
3D ordered maker here in the states Cali.
Edited by KevinM
  • Author
I used to specialize in Aires resin engine kits for 1/48 aircraft..... Kids today dont know they are born with this 3D ,print 🤣
  • Author
This why we ultimately need PE for some things
Actually quite fun to make
  • Author
Bored with folding PE i glued some bits to the deck last night
thats as far as i can go with assembly for now but its renewed my drive as i think its going to look OK.😀 now back to PE and superstructure.
Edited by Paddy
Definitely looks okay Paddy
  • Author
Edited by Paddy
  • Author
I just realised the top of the gun platform should be dark Grey .... bit late now it's glued to the ship and i got the fencing on which should be light grey anyway. In the end i made a small circular ring of masking tape to give me an edge then sprayed the dark grey in situ with a very fine needle in the H&S. its not quite right as it should really be a larger circle but its the best i could do without major surgery on the assembled parts.
Not being a ship guy its just a lack of research on my part. This is my engine room which shows how i should have done the gun platform , the light grey border would only go as far as the railings round the outside, Incidentally your eyes are fine, the engine room is banana shaped and so is the deck it sits on ☺️
Edited by Paddy
Fantastic work Paddy, I feared you would stall with this build earlier on, but now you are on a roll, besides the tiny platform desaster, which nobody would have noted, if you hadn´t mentioned it.
27 minutes ago, Martinnfb said:
Splendid work sir. You are fighting this old kit every step along the way, the end result will be phenomenal. Keep it up
The kit is not old, it dates back to 2016 Martin, I think you mixed it up with the 1/72 version from Matchbox, which layed keel in 1979.
  • Author
That said although its 10 years old it might as well be 50 🤣 The detail is very soft with little definition, The fit of parts is pretty good but the usual ejector pin marks are there and some pretty dire sink marks , mostly in the parts that the Potus set replaces like the depth charges. I would be very intresting to make this again OTB with basic thinning and cleaning of parts and putting this and the OTB next to each other.
