October 17Oct 17 The Tog IIOne of my absolute favourite tanks. Its heavy, Its long, Its ridiculous and I'm sure will be loads of fun.Photo credits to The Tank Museum and WarThunder respectively Edited October 19Oct 19 by Roxy
October 18Oct 18 Author Some starting parts. These "kits" don't actually have instructions or such rather a list of parts and how many of each you will need. And then its up to you as the builder to work out where they all go. They are grouped into sections luckily so there is a bit of guidance there but there's definitely an element of trial and error to working out were they go. And as for the screws for fixing it all together there's even less guidance you have to work it out by the size of the holes and how much stress is going to be on the parts you are screwing. there is a list of sizes and what they get used for so I have a batch of each and nicely labelled up. the wood screws tend to be used for holding all the parts together while the screws on the left of the box are primarily for the suspension. leaving the M2 for detailed and small partsSo far I haveso far I have the sides and bottom of the inner hull printed and put together with a hand full of screws. the torsion bars and mounts for them will be visible on the bottom of the tank.I have also found that this specific tank is designed to have worm gear, Gear boxes were as most on the site use Heng long style Gearboxes. luckily I have the pair from my goliath to check the fit.and after about 3 hours into the 4 hours for the front plate I realised I am a muppet and it needed supports for the hatch opening. but I also learned that it has an issue as for some reason the right side of the hull docent have the groove cut deep enough so I will modify that 3D file to rectify this issue. I also am going to be modifying it to remove the Hull Gun as I dislike that design and would rather have it how the tank appears in War thunder. its clearly removable/removed at some point as the Tog at Bovington doesn't have it installed.
November 1Nov 1 Author Some progress.Takes alot of time to print these parts. This set of wheels alone 30 on that sheet took approximately 9 hours to print. However the level of detail the print con produce is we'll worth the wait for the parts.Also working out what order the parts go in and what screws into where is a time consuming job Edited November 1Nov 1 by Roxy
