1:72 ICM sikorsky CH-54A Tarhe - Review and Build !
ICM 1:72 CH-54A Tarhe
Ref:72001
ICM continues its relentless pace of new releases and modelling innovations.
Following the Hampden, which turned out considerably better than the modeller's abilities, I now present a new challenge, this time a double one: a helicopter and in 1:72 scale.
The subject is not new within the ICM universe, nor is the aircraft itself. Previously released in various scales and themes, the CH-54 Tarhe has now been reinvented in the gentlemen's scale of 1:72.
This initial release depicts the early versions of this true flying crane, first brought into service during the Vietnam conflict throughout the 1960s and 1970s.
It became renowned for its extraordinary heavy-lift capability, being able to carry external loads in excess of 9 tonnes, including artillery pieces, vehicles, aircraft, downed helicopters, and engineering equipment.
There was also the option of fitting a pod capable of transporting troops or being used for medical evacuation duties.
Its distinctive "flying crane" configuration allowed for the rapid recovery of damaged aircraft in combat zones and the movement of heavy loads into areas inaccessible by road, making it one of the most valuable logistical helicopters of the conflict.
This kit allows the modeller to represent an early version of the aircraft, with the option of fitting or omitting the engine air intake filters.
So, what do we find inside the box?
The kit consists of:
  • 5 sprues in grey plastic (typical of ICM)
  • 1 sprue containing the clear parts
  • 1 decal sheet
  • 1 A4 instruction booklet
  • 4 options of decorations
At first glance, the level of detail is entirely in keeping with all recent ICM releases.
The parts feature fine, scale-appropriate detail and offer straightforward construction with minimal complexity.
The components that make up the fuselage structure feature subtle, raised rivet detail, realistically sized and perfectly suited to the scale.
72001_grelha_6.jpg72001_grelha_7.jpgTwo complete engines are provided, which will require careful attention during both painting and installation.
72001_grelha_4.jpg72001_grelha_5.jpgThe support framework and cargo lifting winch are rendered with a sophisticated and modern level of detail.
The fuselage surfaces display the level of quality made possible by modern moulding technology, even in smaller scales (if this model can really be considered small! :D).
Components such as the engines, which remain exposed on the completed model, are particularly well represented and deserve a paint finish to match the quality of the moulding. One of the few configuration options provided by the kit is found here, as it allows the model to be displayed with or without the turbine intake filters.
The entire fuselage features raised rivet detail, convincingly replicating the structure of the real aircraft while remaining appropriate to scale.
The clear parts are on par with other ICM offerings, free from distortion or scratches. A particularly welcome feature is the presence of well-defined framing lines separating the transparent sections from the surrounding framework, which greatly assists during the masking process.
As the instructions and decals , the same formula has been followed . the instructions in A4 format as a booklet, with clear and straightforward drawings.
the decals present nice and well define details and the colours are accordingly.
i do think that the decals for the instrument panels and control columns could benefit with more detail.
ICM also provides, at the end of the instruction booklet, a complete masking guide for all transparent surfaces.
Following my most recent build, my levels of curiosity and enthusiasm for this project are high, so let's move on to the second part:
The fun part! Build and tell
As any construction of these models, the cockpit and all associated parts are the first to build.
The parts and bits they all fit together without any problem.
In a question of minutes, they are ready to paint
The instrument panel was painted in sky grey, followed by a coat of gloss varnish.
Next the decal with the instrument panel was applied and pressed into place with a tip of a cotton bud. In the end a coat of flat varnish sealed the decal. And the result is quite convincing and in scale.
All cockpit interior panel (XF-19), with exception of the floor were painted mate black, all from the tamiya acrylic range.
2710_03.JPGthe seats cushions were painted with vallejo green with washes of darker and lighter tones of the base colour.
Edited by Ricardo Veríssimo
  • Author
Hi all!
A small update on the build process.
the cockpit is glue, joining the interior components to the outside fuselage. The fitting for all parts is very good and strait forward, with no issue at all, as the part have clear channels to glue them and no possible way to miss.
3010_1.jpgthe cockpit masks were easy to cut and apply on the windows.
in this last photo, the instrument panel shows it self in the office. Adequate to the scale.
As mentioned all exterior surfaces are covered with positive rivets and nice and smooth panel where needed.
thanks for watching.
