What is on your bench right now?
Thought I'd try my hand at figure painting, in particular getting the eyes right. I thought maybe bigger would be easier. Not quite but I'll settle for close enough.
  • Replies 167
  • Views 7.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Moon Puppy
    Moon Puppy
    Bench? what bench...I'm rebuilding my work bench right now. I build this out in my shed the other week to give us more storage. I realized it's at the right ride height and depth for a work bench. S
  • Spitfire
    Spitfire
    Still plodding on with my PCM Macchi C202, but I am slowly getting there, this is how it looks now. Cheers Dennis
  • GazzaS
    GazzaS
    Hey, I was just thinking about starting this thread! Anyway... I'm milling out the drain holes on this Revell U-boat. I shoulda done it before I glued the halves together. But I wasn't planning i
Posted Images
Nice Carl😀 I was recently contemplating doing Squirrel-themed MAK
Camel . ((yes, my mind does wander at times) I've seen Anime figures eyes having little white specks or squares to mimic reflections on the eye surface. The egg girls have them , so do most oil portraits. I was wondering how to get that right.
I think your figure looks great......and big.😀
Edited by Belugawhaleman
2 hours ago, James H said:
This just dropped too.
Now all you need is the TiE Interceptor (my personal favourite) to complete the trio.
Working with the decals was fiddly work. Fortunately, most of them turned out reasonably well.
5 hours ago, Martinnfb said:
Grey Matter P-40F/L conversion Sets are gone, so I decided to make my own.
What's the difference Martin?
  • Author
Curtiss P-40F and P-40L Warhawk variants were powered by the license-built Merlin 28, labeled Packard v-1650 ,replacing the standard Allison V-1710 engine to improve high-altitude performance and service ceiling.
The F-14 landing gear graft has been successful. I was able to modify it enough to fit the Takom Ho229.
Spot on, the bodywork looks fantastic.
Here is one question for @Paddy : How did you build up the Unobtanium wire wheels for the Alfa 2300 ?????????
I looked into your log on the other side, but couldn´t find the right answers to my problems. And problems I have a lot with these direct from the start. My set has 0,3 mm steel wire included, but the steel is very soft and bends (too) easy and it´s also corroded in parts, thanks to the conditions where I live.
In the step 1 you are told to insert the pre-cut and pre bended middle spikes according to the Ba on the jig. When I insert all twelve, it looks like this, at least half of them fell off.
What´s even more disturbing, I tried to add the spokes nipples (on non corroded parts), to secure my test spokes and it worked with the first spoke, but with the next, I couldn´t slip the nipple on and destroyed four trying so. I even tried to de-burr the wire cut carefully but no success.
I´m about throwing the wheel into the bin or try another 0,3 mm wire material, which could be complicated to get where I live.
I am guessing you have this Rob ?
https://unobtainium.digital/manuals/alfa.pdf
From memory was the wire supplied in a coil/loop ? I think i changed it for .03mm nickel silver straight lengths from Albion alloys, its readily available on Ebay i think but do a google search, disadvantage is you need miles of the stuff, those 2 bike wheels i did took 40" each so about 7ft.
I used a tiny touch of super glue on each spoke as i slid it into the hub to stop the whole lot falling apart.
Make sure the nipples have holes right through them. I couldn't get them onto the spokes and found under magnification some didnt
these above will never go on as they are blanked but the ones below have holes right through. I expect you have some and some . Drop the guy a line and he will send you some more, thats what i did.
Let me know how you get on or if i can help some more ?
Wow, compared to lacing a real wheel, that actually looks harder. Kudos to you guys for doing it.
Mind you, I guess you don't have to tension each spoke and make it match the others.
Thank you for supplying your spoking wisdom, Paddy. I have the manual and followed it for the first steps and was about to insert the first (middle row) of spokes. The supplied wire is not coiled, but in about 15 cm long rods.
I may give Albion nickel silver a try, it may be a bit more rigid, as it is very easy to bend the supplied wire material, even when trying to slip on the spokes nipples. The nipples, I used were drilled through, I even tested it with a 0,3 mm drill bit, but it is virtually impossible to stick them onto the spokes.
CAing the spokes into the hub for securing them was an idea, I also had, but waited, because I terribly bent some spokes while trying to get the nipple on, that I would have had to exchange them.
I guess, the key is good spokes matrial, which may solve my probs.
I installed the landing gear onto the Horton.
Right side up so she looks less like an upside down turtle.
Mocked up the Horton with wheels and wings.
PXL_20260926_142232417.jpg Nose wheels are from the Tomcat, the mains are F4U Corsair.
Never heard of a Hortosair classic_biggrin.
A Tamiya Tiger metal tracks/barrel first time on both.I have gloss cleared acrylic Tamy brown wash and Florry's sand.I have now sealed that with Testors semi-gloss Florry's sand will be applied again it sticks a little more to the semi them some powders.I totally just made up the camo pattern the pics/print was kinda this and not colors are close methink.This is a test bed.classic_tongue
Edited by KevinM
Well the end is nigh, just applied the decals and gave it a satin coat.
The PCM decals nearly tied me in knots, folding and breaking but I got there in the end.
PCM C202 build (160).JPEGCheers
Dennis
Edited by Spitfire
The Tamiya Tiger getting close it's weathered some my first armor vehicle doing this may do and easy base also.I have a 500W work light about 6'8" up behind me shining down it's better still thinking need a real light just not a fan of LED but I did spy some that changed color?
This pic old camera
Edited by KevinM
Recently Browsing 1
