June 19Jun 19 Author The exhaust has 8 tiny springs that should hold the tail pipes to their support bracket but it will be a better man than me who can fit them.After 20 mins i got one fitted with the aid of 2x glasses and a 20x lens but as i tried to fit the next the first one pinged off. The problem for me is they are too long so it would mean cutting them and forming a new hooked end but to get them to sit right they need a little bit of tension and that makes stretching them and hooking them very tricky ( beyond my eyesight at least).....Its a shame as its a detail thats right on the top of the engine but i think i need to find some other way of doing this. To make matters worse i have lost a very small PE part on one exhaust that also sticks out like a sore thumb.
June 19Jun 19 Wow! That sounds frustrating! Now, when I work with small parts itfeels like I'm wearing mittens.....not to mention my eyesight!
June 20Jun 20 I added the coil springs to the exhaust of my Brabham BT45. I tried it first like you described and got one of eight in place. Then I thought about how to solve the problem and shortened the coil springs, bending them with the help of a sharp blade. Afterwards , I inserted a copper wire into the coil, to keep them bent round. I then glued them in place. Not perfect, but got it done.They are not really visible on the underside, luckily.Cheers Rob Edited June 20Jun 20 by DocRob
June 20Jun 20 Author Brilliant idea rob.I put my mind to it last night and was going to remove the attachment points for the springs, make some new ones and attach the springs to them first before then refitting the attachment points with springs already fitted..........but your idea is better Edited June 20Jun 20 by Paddy
June 20Jun 20 Author the original PE clip is designed for a spring to hook onto.its not really very good anyway as the centre one will need 4 springs attached and its not big enough to get them spaced.I took the PE clips out and tried a 0.5mm wire loopthat works however it looks a bit naff with the kit spring By the time i cut the hook off the kit spring it will be a bit short so I wondered if i could wind my own springs without a hook and cut them too length. so i wound some 0.2mm wire round a bit of 0.5mm piano wire and got thiswhich gives me thisA little bit long but looks better without the hooks.I will sleep on this and probably go with it. As rob will know when viewed with the naked eye it looks fine
June 21Jun 21 Author So this i my solution ( and partly robs 😀)I wound my own springs to 9mm length. Rather than put a wire right through them i just put a wire 1mm inside each end as the tinned copper wire i used to make the spring didnt need a support right through as it tend to stay in the position you bend it.its still not perfect but its the best i can do. You cant expect to take up MFH building and get them perfect after a couple of builds....lol , i doubt i will get them anywhere near perfect ever but thats good because thats what keeps me trying 😃
June 21Jun 21 58 minutes ago, Paddy said:You cant expect to take up MFH building and get them perfect after a couple of builds....lol , i doubt i will get them anywhere near perfect ever but thats good because thats what keeps me trying 😃Looks goo to my eye Paddy. I think there are only a handful of guys, which build MFH kits to perfection. We mortals have to life with the errors and short cuts.The good thing about it, after finishing and some days of distancing yourself from the build, you start to oversee the little niggles and start to like your effort as a whole. At least, that´s what happens with me.Cheers Rob
June 23Jun 23 Author i think this is as far as i can go with the exhaust. i have toned the white down just a little with some tamiya smoke. Moving forward we need and instrument panel and a steering wheel next i think.
June 25Jun 25 Author Wheels in these kits are a joyThe tyres are screen printed with a yellow Dunlop , the rims are CNC turned alloy and the centres are cast in white metal.I sprayed the centres semi gloss black, let it go hard then polished back to bare metal the raised spokes.job done
June 28Jun 28 Author So i added the wing.....threw it across the room....... but it doesnt work ? maybe not big enough 😁
June 28Jun 28 1 hour ago, Paddy said:So i added the wing.....threw it across the room....... but it doesnt work ? maybe not big enough 😁I always like the non winged versions better, these flimsy wing thingies are only in the way to digest the engine.Cheers Rob
June 28Jun 28 4 hours ago, Paddy said:So i added the wing.....threw it across the room....... but it doesnt work ? maybe not big enough 😁2 hours ago, DocRob said:I always like the non winged versions better, these flimsy wing thingies are only in the way to digest the engine.Cheers RobWell, flying away was a characteristic of these wings … just ask Jochen Rindt about it (although it was a Lotus, not a Matra ….)Hubert
June 30Jun 30 Author Well, here it is, it beat me on the finishing line as i couldn't get the nose cone to fit. With hindsight and some surgery, I could do a lot better if i tried again . Its not a model that will make my shelf but I learned a lot building it and it was fun to do. The finished result is just a bit disappointing.In future i would need to spend more time getting parts to fit before painting and decals and put more thought into finding better ways to do certain things than sugested in the instructions.anyway these things are a learning curve and i think if you can finish thinking i have learned enough to do better next time its a win ...Thanks for following 🙂 Edited June 30Jun 30 by Paddy
June 30Jun 30 Amazing work on such a complex.kit. You and @DocRob are the only two folks I know who have managed to finish a MFH kit. Carl
June 30Jun 30 It’s a great result ! My only « gripe » is the absence of the - so prominent on the original - rivets, but your reason not to include them is perfectly valid. And who am I, but an « armchair critic » 😁 ?Looking forward to your next build.Hubert Edited July 1Jul 1 by HuberB
July 1Jul 1 There is always something with these builds that could have been done better, but I hope you will react like me and in a few days after one or two wee drams, you lean back and enjoy the beauty of your Matra, forgetting about the few shortcomings and feel a little proud about what you achieved. She´s a beauty.Cheers Rob
July 1Jul 1 Author I got up this morning and thought i just cant let that nose cone go so after a bit of thinning of the edges where it meets the body, a new small hole and a home made Zeus fastner.......it now hangs together much better, I want to go straight in with a Tamiya RA273 Honda 1/12 and i could do that without feeling better about the MS11 first 😀
July 1Jul 1 2 hours ago, Paddy said:I want to go straight in with a Tamiya RA273 Honda 1/12 and i could do that without feeling better about the MS11 first 😀You know, that there is a Unobtanium replacement for the exhausts available?Cheers Rob
July 2Jul 2 Wow, that's very beautiful work Paddy. I hope that my MFH builds turn out half as nice as yours!I saw something about people doing a test run assembly with bits of CA to make sure everything fits before painting and decals. Once everything fits correctly, they put the model in an acetone bath to dissolve the CA and then build it a second time, this time painting, etc. Seems like you'd need a lot of acetone on a 1/12 model to do that, so maybe they are just doing it on 1/20 and 1/43 builds.Of course, I was watching a video series on a MFH Matra MS11 1/43 kit, and the builder just seemed to paint and build the whole way without any issues. Not sure what the right approach is, but having seen DocRob have some fit issues with I think his Cobra build, it seems like one needs try and pre-assemble the body, or at least pre-fit the sub-assemblies together, to make sure everything fits correctly.All that to say, your build is spectacular! Thanks for sharing it.
July 2Jul 2 Author Small amounts of CA will hold it together but CA on white metal is pretty useless so with small amounts you would easily just pull it all apart again. I have problems with it pulling apart during construction even with larger amounts of CA., Just use a good masking take to hold the resin parts together like Tamiya 5 or 8mm or the like. An ultra sonic cleaner full of water with a glass or plastic vessel that floats on the water with acetone in works really well but its probably over kill as the set CA would flick off metal parts with a scalpel , works brilliantly as a paint stripper on metal and resin parts though.best advice i could offer on any MFH build is buy a small pen drill , i have an arrowmax (or 3) , you will need to drill a lot of holes ( over 500 in the MS11)
